1 - 10 of 10 Posts
Administrator
This is the Club3G's Official FAQ. It hasn't been update in a while, but it still covers virtually every aspect of the 3rd generation eclipse's platform.
Club3G Forum : Mitsubishi Eclipse 3G Forums - FAQ
If you can't find your answer in there, use the search link (orange button on the top). Be sure to introduce yourself in the New Members section if you're new to the site. Enjoy.
Performance Driven
noticed you gear ratios were missing
ITEMS SPECIFICATIONS
Model F5M42 F5M51
Applicable engine 4G64 6G72
Type 5-speed transaxle floor shift
Gear ratio 1st 3.583 3.333
2nd 1.947 2.105
3rd 1.379 1.407
4th 1.030 1.031
5th 0.767 0.761
Reverse 3.363 3.416
Final reduction ratio 3.722 3.736
Speedometer gear ratio (driven/drive) 29/36 28/36
Performance Driven
Model F4A42 F4A51
Type Electronically controlled 4-speed full-automatic
Torque converter Type 3-element with torque converter clutch
Engine stall speed 2100 - 2600 r/min 2100 - 2600 r/min
Stall torque ratio 2.0 2.0
Identifying General Specifications (2 Of 2)
Gear ratio 1st 2.842 2.842
2nd 1.529 1.495
3rd 1.000 1.000
4th 0.712 0.731
Reverse 2.480 2.720
Final gear ratio 4.041 3.728
Performance Driven
Thats ^ from an 02 gt spyder.
This is from an 05 spyder gts
Model F4A42-2-JZB F4A51-2-FZB F4A51-2-LZP
Stall torque ratio 1.9 2.0
Gear ratio 1st 2.842 2.666
2nd 1.529 1.495 1.448
3rd 1.000
4th 0.712 0.731
Reverse 2.480 2.720
Final gear ratio 4.041 3.728 4.011
Performance Driven
This is the manual 05 spyder gts
General Specifications Chart
Model F5M42-2-F6ND F5M51-1-F5N6 F5M51-1-S5N1
Gear ratio 1st 3.583 3.333 2.928
2nd 1.947 2.105 1.950
3rd 1.379 1.407
4th 1.030 1.031
5th 0.767 0.761 0.720
Reverse 3.363 3.416
Final reduction ratio 3.722 3.736 4.111
Performance Driven
curb idle for 2.4
Check the basic ignition timing.
Standard value: 5° BTDC +/- 3°
Start the engine.
Run the engine at idle for 2 minutes.
Check the idle speed. Select item number 22 and take a reading of the idle speed.
Curb idle speed: 700 +/- 100 r/min
1 - 10 of 10 Posts
