Hey guys, I searched and found an old thread with the similar question for a 4cyl and thought i'd go ahead and make another one.
I've had an 05 gt eclipse for over a year now. It's my first manual transmission, so the only other experience I have with sticks is cars I test drove and friends' cars. I've been wondering about this for awhile but figured it was just how this transmission is.
ok, this is hard to explain but I want to explain exactly what it feels like is going on. When the engine is off, i can shift freely without depressing the clutch. With the engine on, I (obviously) depress the clutch, but it takes considerable force to shift to any gear. If I shift slowly, it feels like teeth grab at the shifter and start grinding. I always have to push the shifter past this barrier, in every gear. It gets easier as the gears go up, but first is usually close to impossible to shift into (even if i'm sitting still) Sometimes adding some gas can help, but there is still that rough barrier before it is engaged, and every time I shift it makes a "KLUNK" at the very least. Third fourth or fifth gets away with out "KLUNKing" sometimes.
I'm not mechanically knowledgeable, but I did change the manual transmission oil. I replaced it with the mix that is sold by road race. I also have a short shifter I installed, however this problem existed before I installed the short shifter, the short shifter may have made it more noticeable, however. I also put harder bushings on the shifter tower.
If anyone has the time to read all that and try to help me out I appreciate it. I'm not looking for the smoothest shift ever, I just want to make sure I'm not damaging my car
thanks i really appreciate it
