Pretty Pretty Panda
okay. this is the first time i've ever had to replace my clutch, it lasted a good 70k miles or so with me which is good. im not too sure what kind of clutch i should put in. its a non-turbo 2000 GS.
anyone have any suggestions on what is better?
Pretty Pretty Panda
i was lookin at an ACT/F1 clutch kit. ill probably end up tryign that one since my car is only a 4 banger :p
I'd suggest any "Stage1" clutch if you don't intend to go FI within the next 60K miles. Personally I use a Spec Stage 3 but I have had no problems with it. I know some people have had problems with Spec clutches but I guess its a hit or miss issue. Mine installed fine and has been working great. I might also suggest installing a lightweight flywheel, while you do the clutch, if you can afford the extra $300. No extra labor charges if its installed along with the clutch plus it will give you a little more performance.
