1 - 9 of 9 Posts
hi all,
When doing the valve cover gasket for eclipse, i remove the top timing belt cover and notice that the gasket inside is already cracked.
43047
is there a replacement for that section or do i have to buy the whole set?
Thanks.
Discussion Starter #2
I found it on mitsubishi website and it's not bad.. less than $3 for the gasket..
43073
Reactions: GTSDriver2003
Geez.. some of the gaskets are discontinued.. no mitsubishi dealership nation wide has it.. is there any other type of gasket we can use as a replacement?
Discussion Starter #6
Actually i can measure the slot with the open cover..
Do'h...🥴🥴🥴🥴
Reactions: buddd
Discussion Starter #7
It's 3/8" but the gap is square not round like silicone cord.
43075
Discussion Starter #9
I bought 10 ft of the silicone cord for $8.99 compare to get the set of gasket from Mitsubishi Factory Warehouse for over $85.
10ft should be more than enough for these covers.
Reactions: buddd
1 - 9 of 9 Posts
