Okay so i know this is on here a lot but i need some advice, I just bought this eclipse due to it not starting right off the bat the person said he had diag. it to the crank sensor I replaced that and checked timing everything on that side looked good. i went to start the car still nothing. I asked him what the car did and he said it just cut off while he was pulling into a parking lot and wouldn't start back up. So after hearing that I immediately went and checked fuses all fuses was good so i checked fuel I can't tell if i'm getting fuel due to this car not cycling the pump until the 150RPM range but I put my hand on the pump while starting and I didn't feel anything move so i tried to confirm my theory by spraying starting fluid into the throttle body and it still didn't fire and I can't check for code due to the i guess first owner decided that he was going to unplug or get rid of some wiring because my ob2 port doesn't even have power i'm at a lost on what to do
it's a 2000 eclipse 2.4L with a manual 5 speed
