1 - 3 of 3 Posts
Vx_Lotus
Bought a 2000 gt
42868
Has Crank, Fuel, Spark, no codes in the OBII reader. Fast Crank, Fully charged battery, A/C compressor is removed, No key fob, just a black key, Security alarm was reset by a friend, need help. We checked all sensors / relays, plugs, wires, distributor which has been replaced 3 times. (Timing belt is good, engine turns manually) it has a 5spd transmission, engine is a G7S4FF 6g72 - it has Dual exhaust, no speaker wires ran, and an Injen long ram cold air intake. We tried 2 fuel pumps, both did the same thing, we tried the fuel relay bypass with a paperclip, we can hear them kicking on. The engine is new we were told, but it hasn't ran yet. Please help.
Check spark plug wires are hooked to the correct cylinders. Also check compression. If you're getting fuel and spark it should fire if you have compression.
Vx_Lotus
Hi, thanks for the reply.
150 psi in cylinder 1, have not checked 3, 5 yet. (firing order looks correct)
1 - 3 of 3 Posts
