I was wondering how many mA should be going to the +5 to the amp? I got a complete circuit designed to allow me to use my 30gb zune player as a headunit. Just need to make sure there isn't a required mA or A that needs to go on the +5 terminal(s) of the amps.
the remote wire, or little blue wire. Im pretty sure it is 5 volts. Reason im asking about mA is if it doesn't require alot then i can use cheap transisters, ect.
Car Audio Mod #3
Remote wire is 12V. You will need about 100-200 mA of current. If you have more than 2 amps, you can use a relay to trigger a higher amperage source.
