1 - 3 of 3 Posts
I was doing some thinking and was trying to find a way to sharpen my steering set up. I had come across what is called a cut knuckle which pretty much shortens the arm where the tie rod end is attached to the steering knuckle, which changes the geometry. (normal steering wheel input, extra angle at wheels)
But I was wondering if anybody had don this to their cars or have found a way to sharpen ones steering,
thank you, and cheers
You might want to start with doing a brake upgrade if your planning on road racing. Biggest problem with theses cars are that there heavy and they heat up way too much causing the brakes to lock up. Evo brake upgrade is a must before everything else if that's the plan of direction your taking with the 3g.
1 - 3 of 3 Posts
