1 - 20 of 242 Posts
New Rider
I do not "think" that there is another thread like this. But either way, it is nice for an update.
Some of this I have already, some I am buying.
I chose the 6 core because I always have multiple programs running at once and I hate waiting. And the 8 core is overkill. Going 16 gigs of RAM. Do not need 32 at the moment. Also, that water cooler is a nice small system and although I most likely will not really need it, the price is very good.
The whole system ran about $640.00. Sure, I might have skimped here and there, but that is a great price.
Also, many of you will scoff at that video card, but I am not a gamer. And besides, I got it from a co worker for 20 bucks. Beat that!
Will post pics of the final product when it is.. well, final.
Antec 900 case.
Newegg.com - Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Unique Top mounted 200mm TriCool exhaust fan to cool the hottest system
Perforated front bezel for maximum air intake
Two front loaded HDD cages for up to 6 hard disk drives
The HDD cages act as air ducts to take air in more efficiently
Top mounted I/O ports for easy access
Top tray for your MP3 player, digital camera, etc.
9 Drive Bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3x 3.5" for HDD, or
- External 9 x 5.25"
Cooler Master GX Series 650W ATX 12V V2.31 80 PLUS SLI Ready Power Supply RS650-ACAAE3-US
Amazon.com: Cooler Master GX Series 650W ATX 12V V2.31 80 PLUS SLI Ready Power Supply RS650-ACAAE3-US: Electronics
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Newegg.com - GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Get Ready for New Generation of 32nm AMD AM3+ CPU
Supports next generation of 45nm AMD AM3 CPU
32 Gig RAM Max
Multi-display support with 2 way SLI and 2 way CrossFireX
AMD OverDrive Support
108dB Signal-to-Noise ratio playback
DualBIOS 3TB+ HDD Support (Hybrid EFI Technology)
Turbo XHD- Full Automatic RAID 0/Stripe
Ultra Durable 3 – Classic
GIGABYTE innovative technology- Easy Energy Saver
AMD FX-6100 Zambezi 3.3GHz Socket AM3+ 95W Six-Core Desktop Processor FD6100WMGUSBX
Newegg.com - AMD FX-6100 Zambezi 3.3GHz Socket AM3+ 95W Six-Core Desktop Processor FD6100WMGUSBX
Core - Zambezi
Multi-Core - Six-Core
Name - FX-6100
Operating Frequency - 3.3GHz
L2 Cache - 6MB
L3 Cache - 8MB
Manufacturing Tech - 32 nm
64 bit Support
Hyper-Transport Support
Virtualization Technology Support
Thermal Design Power - 95W
XFX ATI Radeon™ HD 4850 - 625 MHz Core 512 MB DDR3 HDTV Dual-Link DVI - HD-485X-YDFC
Graphic Card Models
GPU Clock MHz: 625 MHz
Shader Clock (MHz): 0 MHz
Stream Processors: 800
Bus Type: PCI-E 2.0
Performance: Standard
Memory Interface Bus (bit): 256
Memory Type: DDR3
Memory Size (MB): 512 MB
Memory Clock (MHz): 1990 MHz
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
Newegg.com - CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
Speed - DDR3 1600 (PC3 12800)
Cas Latency - 9
Timing - 9-9-9-24
Voltage - 1.5V
Antec Kuhler H2O 620 Liquid Cooling System
Newegg.com - Antec Kuhler H2O 620 Liquid Cooling System
Low profile pump ensures exceptional liquid circulation while preserving internal airflow
Easy-bend tubes for maximum flexibility in radiator positioning
Intelligent noise / speed control fan for quiet, efficient cooling
Latest generation copper cold plate for optimal conduction
Cooling Liquid - Safe, environmentally-friendly, anti-corrosive
Chuck Nasty
amd 8120 overclocked to 3.4
16 gb corsair 1600mhz ram
asus 990x board
nvidia gtx 560
thermaltake 800 watt power supply
1 western digital 1tb hard drive
2 seagate 500gb hard drives
asus dvdrw drive
corsair h50 liquid cooling
12 fans
cooler master elite 430 case
creative xifi titanium sound card
sabrent wifi card
plays any game maxed out with 30% cpu usage and play skyrim maxed out at 34 degrees celsius
devil may cry 4 at 400 fps
New Rider
asus 990x board
nvidia gtx 560
asus dvdrw drive
12 fans
sabrent wifi card
Pics? Also, I forgot storage. Going with one 64gig SSD for OS. That is about the only thing worth noting.
Detailing Pro
Processor: Duo Core OC'd from 3.0 to 3.33Ghz
Memory: 4GB
Hard Drive: 640 GB
Power Supply: 1000W (used to be 750, and it took a dump so just did really an unnecessary upgrade to be safe)
Video Card: Radeon 4890 1 Gig
Monitor: Samsung 26" LCD TV
Headset: Turtle Beach AK-R8
Speakers: Surround Sound
Keyboard: Logitech G11
Mouse: Death Adder (or Razer Mamba depending on what mouse I use on my laptop)
Operating System: Windows Vista 64bit Ultimate
Since I'm starting Solidworks (CAD) this semester I'll probably up the RAM to 8GB.
This was built a little over 2 years ago. Still works flawlessly except for a minor thing that we setup wrong with the HD (supposed to have like 100GB for the software and save onto the rest of the disk, but that worked out incorrectly and I just deal with it since I can manually move the files onto the other part of the HD)
Imageshack lost my pictures of it, so I'll get or find them later and update this.
Ur a worthless noob
Case: Corsair 650d
Processor: Intel i7 2600k
Cooler: Corsair H70
Memory: Corsair Vengeance 8 GB (2 x 4 GB) DDR3 1866 MHz (PC3 15000)
Monitor: Dell u2410
Speakers: Logitech Z623 (Got an extra if anyone wants to buy it)
Mouse: Logitech Performance MX
Keyboard: Logitech K800
SSD for OS: 96gb Kingston
HDD: 1.5tb and 1tb for various manufactors
I am using an old video card since I am not a gamer so why waste 300 or whatever for a vid card that I wont use and when I do... it will be old news. Dont even know why I built this... probably since I was getting bored with my old Athlon X2 3600 or whatever many many years ago.
Not bad though. My PC consistently stays around the low to mid 30s degrees C
Chuck Nasty
Chuck Nasty
Chuck Nasty
Chuck Nasty
build one. i would put my computer stuff i have for sale up but i have someone who is interested at work that i am building 2 computers for.
Fear my erep power
Built my current rig a while back:
coolermaster case air cooled
1000 watt corsair power supply
Q9450 (quad core) OC from 2.4 to 3.2.
I forget ram speeds but I got 4GB of corsair
evga 580GTX and for physics I use a 8600GT
evga 750i SLI FTW
1 raptor drive, one big ass other drive
onboard sound
logitech g15 keyboard
logitech g35 headphones
logitech MX1000 mouse
Cooler master Stacker 210
A few TB of platters in RAID and non RAID
120GB SSD
4GB 1066 DDR2
Abit IN9-32X MAX (680i SLI)
E8400 @ 3.6Ghz w/ 1600Mhz FSB and HT buss at 5x multi. Only very minor bumps in system voltage to enhance stability.
750W PSU
BFG 9800GT
Oh yes, top of the line indeed. :lol:
New Rider
Discussion Starter #15
You are not as old as me...
Intel Core 2 1.86 GHz
2.0 Gig DDR2 RAM
32 bit Win Vista
160 Gig storage
It sucks when the best part of your system is the 19" flat screen monitor.
hookers and blow
Intel Core i7 2600k
Gigabyte GA-Z68XP-UD4 mobo
Kingston HyperX 16GB RAM
Sapphire Radeon HD 6850 1GB
Couple of TB of storage across various drives.
Wut Wut In Da Butt
2.0 Gig DDR2 RAM
32 bit Win Vista
160 Gig storage
:lol: I don't feel so bad now. :kiss:
Intel E6400 Core2Duo 2.13Ghz
Windows Vista 32bit
4GB RAM (only 3GB used)
250GB HDD
500GB HDD
ATi Radeon HD 2600 XT PCI-E 512MB
22" monitor
and over 4TB of external HDD storage
My new laptop has Intel i3 and 8GB ram :lol:
Hammer Time!
I have a quad core i7 930 @ 2.8GHz, 12GB triple-channel DDR3, 4x HP 146GB 15kRPM 2.5" SAS drives connected to a 3Ware RAID controller in a RAID-10 and an Antec black case. It's connected via Gig-E directly to a T3 internet connection; guaranteed full 45mbps up/down, but consistently hits 75mbps. :agreed: Also have up to 60TB of iSCSI storage on tap if required.
My system fucking rocks the block. /thread
Patty Cakes
Intel Core i7 920 2.66GHz (OC'd to 3.67GHz on air)
Zalman CNPS 9700NT HSF
Asus P6T6 WS Revolution NF200 motherboard
12GB Corsair Dominator DDR3-1866 @ triple-channel
3x EVGA GTX 285 Superclocked @ 3Way SLi
Thermaltake Toughpower 1200W PSU
1x Lite-On Bluray/DVD R/W (SATA-internal)
1x Seagate 500GB 7200RPM HDD (SATA-internal)
1x Seagate 1.5TB 7200RPM HDD (SATA-internal)
Dell Ultrasharp 3007WFP-HC 30" 2560x1600 LCD monitor
Microsoft Natural Ergonomic Keyboard 4000
Logitech G5 Laser Mouse
Razer steel mousepad
Altec Lansing stereo headset
No desktop anymore, just my humble laptop I got for birthday last summer.
HP dv6 model:
ATI Mobility Radeon HD 5650
Intel Core i7 Q720 @1.6Ghz with Turbo Boost up to 2.8 GHz
500gb HDD
6gb DDR3 Memory
Got a free arcade xbox 360 (new version) when it was ordered.
1 - 20 of 242 Posts
