1 - 2 of 2 Posts
Adding a diamante tb to the engine build, here's the issues I'm seeing. I've done some measuring and it seems really close to fitment. will I need to take a hacksaw to my firewall or the tb itself to fit this in? Other problems: sensor plugs don't match (do the colors correspond on the harnesses?), and god dammit I broke the F-ing diamante TP sensor in half. I took the TP sensor off the eclipse tb and did some machining to extend the butterfly axle and key fitted the eclipse TPS onto it with some jb weld. Here's my dilema: how can I test if this works? Or would it be wiser to find another Diamante tps and put it back on stock? It's going to suck huge ass if I get this engine in after 3 months of work at this sensor gives me issues.
Other random question. With the swapped/ported mani's, tb, ported heads with cams, and high comp ratio pistons, where do I start on fuel injectors....????? Can't find any threads that cover injectors for a built N/A 72
1 - 2 of 2 Posts
