1 - 3 of 3 Posts
2001 Mitsubishi Eclipse GT Spyder
Hello!
I’m currently in the process of doing a manual swap on my 01 sporty GT. I have most of the parts I need:
Transmission
Slave Cyl/plumbing
Brake/Clutch pedals
Shifter/shift cables
Clutch/pressure plate/flywheel (on the way)
I’ve read that I’ll need a passenger side axle, but in my research I’ve found that the AT and MT axles are the same. Can anyone confirm?
I think I have all the parts I need. Let me know if I’m missing something! I’ll be making a full guide to share with everyone!
Thanks,
Logan
I believe the only difference is the half shaft for the passenger side. It's the small part of the axle that goes into the transmission and then the bearing portion of it bolts to the back of the block. There is about a 1/4" length difference between the two.
Thanks for the reply,
Do you have the part number for that axle or know where I can buy one?
1 - 3 of 3 Posts
