Hey all, I've searched and searched and tried multiple different things and this is what I came up with. My dimmer switch was working when i got the car. No radio, nothing connected. I'm pretty sure I remember it working. But I noticed it stopped working either after I put the radio in or after I swapped my dash gauges to LED. I've put a new switch in, tried jumping the dimmer switch (blows the fuse under hood) I've checked all the fuses, looked for any kind of resistance numbers on the switch and nothing. As far as I know the LED's don't mess with the dimmer. The head unit shouldn't also? (Previous owner cut the plugs off so I've done a lot of testing and trial & error to get the wiring right. Factory amp, radio has 3 pre outs (front rear subs) The pink wire is the illumination wire correct? That's connected to the orange dimmer wire on the back of the pioneer head unit. Regardless of connected or disconnected, still doesn't work. I've grounded out everything I can, gotten as much taped up and away from metal as I can. The dash lights come on and stay on even with the switch unplugged. They're really dim like at the lowest setting and I can't see them hardly even at night. Bulbs are good and bright, got them from SBL.com, this is starting to annoy the living crap out of me. I've checked the wiring, stock gauges, no shorts, no cuts, continuity is fine up to the switch. NOTHING. the odd thing is. I put my switch in my buddys eclipse....it works just fine......I'm stumped, there HAS to be a wiring issue somewhere for this not too work. Or my gauges are screwed up. Not sure, one or the other. I'm just tired of squinting to see my speedo at night. Anyone out there have a clue?:dunno::dunno:
