You did what?
Hi all...
Just have a small problem. The drivers side door won't lock, even when i try to turn the key. Its like there is something stuck. Even the power locks wont lock either (except the passenger side). Does anyone know what it could be???
Thanks
:dunno: Take apart your door panel and see whats wrong visually. Shouldnt be too complicated.
:agreed:
It sounds like it's a mechanical problem, not an electrical problem...otherwise, it would still work with the key...
You did what?
Discussion Starter #4
:agreed:
Exactly what I was thinking. Was thinking about taking it somewhere but they want to diagnose it and i keep telling them that i dont think its a electrical problem. So im just going to check it out myself.
Sounds like your best option...once you get the panel off you'll probably find a linkage disconnected (I'd imagine the problem is at the latch itself since the key and the electric actuator both don't work)...hopefully nothing is broken, but just disconnected...
