1 - 2 of 2 Posts
Hey, i've had this issue for a while and its getting old .. every time i hit unlock (via remote or from inside car) the drivers side makes a loud clicking noise that last maybe a second or 2 ..
for starters ..
2000 eclipse GS, sportronic, ~195k miles
this is a bit hard to explain w/o pictures so bear with me...
i've taken the door apart and removed the locking mechanism to find that when it unlocks there is a part that moves into place against a plastic piece that stops it from going further.. that plastic piece has worn down so the motor or whatever thats in there thinks it can go farther & tries to do so, but gets stopped. in trying to push the piece farther & getting stopped it makes this clicking noise.. previously i tried putting something up against the plastic piece so it would stop the lock at the right place.. that worked for a couple months, but the issue has resurfaced..
if your unfamiliar with what im talking about, you probably wont understand from my description.. but im hoping someone out there has dealt w/ & found a fix for this issue.
(also i know this isnt specific to this model as i've ran into someone who had a different make of care w/ the same issue)
thanks in advance for any help
Boobs!? WHERE!?!
Well it sounds like you found the problem already! What exactly are you asking for? Just replace the worn down piece.
1 - 2 of 2 Posts
