Brake lights and turn signals work fine. Checked the fuse for driver side running lights, it was blown. replaced it and lights flashed then went out again (blown fuse again). It says use a 7.5 but when i got the car it had a 10 in that slot. Maybe because the guy installed those little hood lights on the washer jets hooked into that side. Worked for a month then this happened. Checked the bulbs and wiring that was accessible. No problems that I could see with the stuff I could get to. I checked all the fuses and every one of them is good except for #21 I think (Whichever is the left side parking lights). Is there maybe something I missed that could be a problem? Something common maybe? I know I saw another Eclipse GT with the same issue.
