1 - 2 of 2 Posts
swapping out engines to a different car with ECU can I bypass the immobilizer by not taking it and putting it in with the engine
If you are replacing an engine with the same type of engine, you don't have to worry about the immobilizer. You only have to worry about that if you start swapping ECUs around.
1 - 2 of 2 Posts
