I'm having a hell of a time getting my engine to start right now. I have 440cc injectors from Tearstone (I believe they are Ford Motorsports brand) and an E-Manage Ultimate sitting in front of the ECU.
The E-Manage Ultimate is wired and configured for add-only compensation on the injectors. Here are the settings in EcuFlash:
Injector Scaling: 522 cc/min
Injector Battery Voltage Latency Compensation:
4.6875 V - 6.120 ms
7.03125 V - 2.544 ms
9.375 V - 1.344 ms
11.7188 V - 0.792 ms
14.0625 V - 0.552 ms
16.4062 V - 0.120 ms
18.6768 V - 0.000 ms
When I pull out my plugs, they are saturated with fuel. I can get the engine to start by first unplugging the front 3 injectors, and later plugging them back in once the engine turns over. I know this issue is very similar to the one ryu was having, but my timing is dead-on because the engine runs perfect once I get it started.
PS: I previously used the E-Manage Ultimate to scale the injectors; this worked fine for several months, so I figure the injectors are not bad.
4.6875 V - 6.120 ms
9.375 V - 1.344 ms
