First off, thank you in advance for any help. I have a 03 eclipse GS. It has a cai and a catbac exhaust. I got the car new in 04. Now it has about 129,xxx miles and about 2 months ago my accesorys stopped working. More specifically the windows, moon roof, radio, clock display, and keyless entry. I checked the fuses under the hoods and under the dash. They are all good and getting power. I looked for loose wired and wiggled and pushed on them to see if any loose ones with no prevail. If I'm leaving anything out I apologize. Again thanks for any help.
Fuck salt.
Check the fuse under the hood again with a fuse tester.
Fuck salt.
You checked the ones in that little yellow plastic section with a fuse tester?
I apoligize, I checked the fuses, the one row works, like headlights talights turn signals etc, but the other row is showing now power which is weird because the horn is one of the but the horn works.also dicovered the my hazards work when my car is on (running) but not off. I did check the yellow box fuse and it was good. I appreciate you trying to help.
