Im looking foward to the build seeing as I want to do this myself but wasnt sure on everything, Keep Us Updated
thank you.10 6 1 3 7
9 5 2 4 8
Those are the head bolt torque specs. Torque all bolts to 58ft-lbs in the correct sequence. Loosen them all in the correct sequence. Then torque them all down to 15 ft-lbs and then an additional 90 degrees, again, in the correct sequence. Then go back and torque each bolt an additional 90 degrees.can someone explain this me please?
78 ± 2 (58 ± 1 ft-lb) → back off→ 20 ± 2 (15 ± 1 ft-lb) → 90° + 90°
i have the thermostat houseing already, i didnt know i needed the pipe!You need the water pipe and thermostat housing from an EVO.
Cam gear bolt is a 17mm. Impact gun works best to take that off. If you can't, remove the valve cover and you can fit a 1 1/16" wrench on the cam and then use a breaker bar w/ a 17mm to get the bolt out. The wrench is to keep the cam in place and not spin.
There are notches on the valve cover for where the cams should align to.
o that car, thats just some ******* car. he loves to SUCK MASSIVE COCK.::ghey3: Hes also pedophile. :loser:damn thats a nice red 3g in those pics who's car is that
