F5M42-2 Dog Box ?
4615 Views 5 Replies 2 Participants Last post by  RichardB
Anyone know of a gear set that will fit an F5M42-2 Gearbox to convert it into a dog box?
Check at the bottom of this website. What are you running that you are wanting a dog box for?
http://www.cascadeautosport.com/parts/
Chris.
Chris.
Ive got a mitsubishi fto, currently pulling 400+bhp 400+lb/ft torque
Do you live in the US?
I wanna see some pics!
Chris.
Sorry to resurrect an old thread but some of you may know my FTO drag car and the developments its been through, from standard FTO to 6A13TT to 6A13T running 660bhp, now evo engine running almost 1000bhp.
FTO Racing
During this time I've developed many custom parts for it and one is an F5M42 Dog Box. This cost me quite a few £'000 to design and develop and now that I've switched to the EVO box it of no use to me.
Unfortunately I damaged it when my clutch let go, so it needs a new 5th gear, and possibly input shaft (you may get away with the input shaft as the clutch still fits it) for that reason I'm letting go very cheap, £1750 for the dog kit if anyone is interested.
Both Glebe Home Page:: CAD/CAM Prototype Precision Engineering CNC Wire Erosion Toolmaking Toolmakers Assembly Manufacture Small batch Grinding Turning Milling Design Bespoke Machining Machined Components Specialist Complex and Elite Racing Transmissions | Racing Gearboxes | Stoke on Trent have said they would be able to re-manufacture the parts required, and I've used glebe to replicate some of the existing gears when I wanted to change ratio's and they were about £200 per gear at the time. So it should be a cheap fix.
The gear ratios are
1st 2.846
2nd 1.941
3rd 1.391
4th 1.037
5th 0.833
