SETUP:
RIPP SDS Stage 2 w/ large shaft pulley, large crank pulley, 14psi
310cc injectors, inline Walboro pump, malpassi FPR, GTS manifold
RIPP 9.5:1 forged pistons, decked and balanced block, P&P heads to lower manifold, RIPP headers with 1 high flow cat, ACT clutch, Fidanza flywheel, Quaife LSD, RIPP meth cooler.
The vehicle currently has the stock 2.25" catback exhuast with a Flowmaster muffler.
Guages: EGT, Boost/Vacuum, AEM wideband. EGT is in cylinder #4 exhaust 8in. from head, and wideband is in the fron header just before the "Y" pipe.
Car has 1800 miles on SDS. Idles perfect at around 14.7, and set on cruise the car stays STOICH. At part throttle and WOT the A/F ratio drops to 10.0 and the car runs like it's on two cylinders. The car goes into boost fine without any detremental effects. The only codes I throw are P0300 (every time the car is driven), and P2229 (what is this?). That's about it. Even before the SDS, but after the engine rebuild and header install, the car would run like crap in the rain or after going through a drive through car wash. Heavy amounts of water on the undercarriage have a negative effect on run condition. I've checked the O2 connections and they don't seem to be letting water in, as far as I can tell. The last time I launched my car from a dead stop, it blew the flex section loose from the Cat, in first gear. It made a loud boom as if the exuast coming out of the engine could not flow out of the cat and stock exhaust, and had to come out of the path of least resistance. This has caused no O2 or CAT codes at all. My car simply sounds like it has a hole in the exhuast, and it goes away once it warms up, that's it. No other change in driving. I have not and will not go into boost until this is fixed.
When the car does drop to 10.0, I can let off the throttle or downshift and then lightly press the throttle to get it to go back to 14.7. It's as if it get caught in a loop so long as the throttle stays wher it is until it's adjusted.
