1 - 2 of 2 Posts
Vehicle History report attached
Driven 270,000 miles
Asking $2200.00 (No shipping)
  • COLD A/C!
  • KYB AGX adjustable shocks/struts
  • EBC slotted/dimpled rotors with Yellow Stuff pads and 2000 model dual piston calipers.
  • Magnaflow exhaust from the manifolds back installed four years ago.
  • Ingalls stiffy torque damper
  • Timing belt maintenance done regularly (will be due again in about 20k miles)
  • New battery
  • New fuel filler neck
  • New wire harness driver side door
  • New hood release cable
  • polyurethane motor mounts
  • Rebuilt rear suspension 2 years ago with polyurethane bushings
  • ST Suspensions 7/8" Rear Anti-Sway Bar
  • All steering and suspension parts have been replaced by Moog parts as they wore out
  • New (Moog) inner tie rods
  • Jensen multimedia Bluetooth receiver (stock radio included as well)
I'll also be including an extra set of rims (the stock ones) along with some other miscellaneous items. Maintenance records available
The bad: The car does throw the P0456 Code (small leak in EVAP system). Smoke test showed it coming from the vapor canister. Occasional ses light for cylinder misfire. Driver outside door handle loose, bolt stripped. Fairly clean, has some paint fading on the trunk lid, some rust starting to form where the trunk meets the bumper, and stone chips on the front bumper. I'm happy to answer any questions, please feel free to ask.
42499
42500
42501
42503
42504
42505
42506
42507
42509
1 - 2 of 2 Posts
