1 - 12 of 12 Posts
ASE Master Tech
Looking for $400 shipped firm. You get 2003 Outlander intake manifold, Tps sensor and Throttle body. Please No lowball offers
ASE Master Tech
Discussion Starter #6 (Edited)
04gsNA you nice any gains with this? How easy is the install?
Yes I notice a gain in power when used. Never took it to the dyno though to get actual #. It uses a bigger throttle body than the eclipse/galant. Throttle body is said to be 60mm unlike your 54mm. It is pretty easy to install. It bolts right up. All you need to do is extend vacuum lines and some sensor wires. Took me about 2.5 hours to install.
goosey2099 6 pack of corona?
Lmao don't think so but the guy is pretty close in N.Y. if you want to install it for him ;)
The mani doesn't fit v6 cars only I4 4g64 sohc cars.
Last time I checked, I had the 4G64...yup, it hasn't grown 2 extra cylinders yet. :nuts: Sorry to give you a hard time, but the RS and GS Eclipses don't have the V6 (unless someone swapped one in...only the GT and GTS)...
Someone correct me if I'm wrong, but I believe there are clearance issues with the Outlander manifold in the 3g Eclipse...that's what I was referring to...it's one area that you guys with the Galants have it good...
QuickSLVR
I remember reading something about it on here, and it wont clear cause of the firewall
ASE Master Tech
Discussion Starter #11
Sucks I guess I'll just leave it on tgc for the galant guys. If any mod knows for sure that it doesn't fit then please lock this thread. To the others thanks for looking.
1 - 12 of 12 Posts
