Up for sale I have two directed audio amps. One is a 4 channel and the other is a mono class D amp. Specs are listed below. The 4 channel will come with 2 sets of soche RCA cables and the mono with come with one set of monster RCA cables.
Prices:
4 channel-$110 shipped and paypaled
mono-$130 shipped and paypaled
Directed Audio D1200:
* Class-D Monoblock Amplifier
* Super-efficient Class D PWM design runs much cooler than conventional amps
* RMS Power Output:
o 300 watts x 1 chan. @ 4 ohms
o 400 watts x 1 chan. @ 2 ohms
o 600 watts x 1 chan. @ 1 ohm
* High-speed MOSFET switching power supply
* High-current complimentary Class D MOSFET outputs stable into one ohm loads
* Thermal, DC offset, reverse polarity, and short circuit protection with status LED
* Continuously variable 12dB/Oct low-pass crossover
* Switchable 24dB/Oct. subsonic filter
* Switchable 8dB bass EQ
* Switchable 180° phase inversion
* Remote subwoofer level control
* Master/Slave Function
* Variable input sensitivity: 150mV - 7.5V
* Chrome-plated wire terminals and RCA connectors ensure maximum signal transfer
* Rugged 2-piece heatsink and cover
* RCA Outputs: 1 pair
Directed Audio A404:
* 400 watts 4-Channel Amplifier
* RMS Power Rating:
o 4 ohms: 45 watts x 4 chan.
o 2 ohms: 50 watts x 4 chan.
o 4 ohms bridged: 100 watts x 2 chan.
* Thermal, DC offset, reverse polarity protection
* Rugged two-piece extruded heat sink and cover
* Built-in high performance, 12 dB/octave 2-way active crossovers
* High speed MOSFET switching power supply
* Bipolar outputs
* 2 or 4 channel input capability
* Switchable 8 dB bass EQ function
* Dimensions: 11-3/8"L x 10-3/4"W x 2-1/2"H
Prices:
* RMS Power Output:
* RMS Power Rating:
* Bipolar outputs
Still available
Super Moderator
jpkennedyll1974
If you look at the date of the post you replied to I doubt very much you will get a response. That was for sale13 years ago... Please have an eye on the date of the post before posting.
Now that's is out of the way... Welcome to the site. Please take a moment and complete your profile so we know what you are driving and where you are from.
