1 - 13 of 13 Posts
Zero Resistance, LLC
I have a bunch of OEM stuff I've accumulated over the years and it's time to make some room. All parts came from running cars. Prices include shipping and everything is OBO. Payments through paypal only.
3 x Throttle Position Sensor (TPS) All Models - $30 each
2 x MDP sensor MD305600 - $30 each
2 x EGR Solenoid - $30 each
1 x EGR Solenoid w/GT bracket - $30
1 x EGR Solenoid w/4cyl bracket - $30 each
1 x Evap Solenoid w/GT bracket - $30
2 x Evap Solenoid w/4cyl bracket - $30 each
2 x Vacuum Valve All Models - $20 each
1 x Set of six 210cc injectors - $45
1 x Set of four 240cc injectors - $35
1 x Set of four 275cc injectors - $50
2 x RS/GS Coil Pack - $30 each
2 x RS/GS Slightly Damaged Coil Pack - $15 each
1 x RS/GS Camshaft Position Sensor - $30
2 x Ignition Failure Sensor - $20 each
1 x Speed sensor from a 4cyl MT - $30
<s>1 x Mass Airflow Sensor (MAF / MAS) 501 - $60 sold</s>
1 x V6 Crank position sensor - $30
2 x RS/GS EGR Valve - $30
1 x V6 EGR Valve - $30
1 x Driver Side Window/Lock Switch - $35
1 x Passenger Side Window/Lock Switch - $25
1x MAF sensor Harness - $15
4 x Stock Injector Clips - $10 each
1 x V6 rear bank injector harness - $30
1 x MDP harness - $15
1 x Speed Sensor Intermediate Harness - $15
1 x ECU 2.4l, auto trans, federal 2001 MR507245 - $50
1 x ECU 2.4l, auto trans, federal 2000 MR420680- $50
1 x ECU 2.4l, auto trans, all 2002 MR578505 - $50
I'll add more stuff as I find it.
Damaged Coil Packs. Damage will have no affect on functionality or installation.
Pandora
i saw your old posting about having stock injectors. i was curious if you had 6 stock GT (v6) 2002 injectors. let me know if you have them and for how much shipped to 95118.
thnx
Pandora
how many miles do the 210cc injectors have on them? your damn pm box is full. :)
1 - 13 of 13 Posts
