1 - 2 of 2 Posts
I have an aftermarket fuel pressure regulator for my RIPP SDS set-up. I recently replaced the IAC valve on my Eclipse GS and removed the intake piping along with the battery. In putting it back together, I found this vacuum hose from the front of the aftermarket fuel pressure regulator disconnected.
Where does it hook up or connect to?
I've searched and also looked at SDS owner's manual. However, I can't seem to find where it connects to. All the available vacuum ports and nipples seem to already be connected with existing hoses. This includes the vacuum lines to the blow-off valve and I don't see any open ports on the throttle body.
That's going to depend on who installed it. It needs to go to the intake manifold in one way shape or form. I'd check everything over very thoroughly. Running without that hooked up will result in a blown motor.
1 - 2 of 2 Posts
