Fuse #8 (20amp mini fuse) in my 03 GTS keeps blowing every couple of days, I'm currently having trouble tracking down the source, has anybody else dealt with this issue before, the fuse being blown will cause crank no start.
i actually have a brand new one but i couldn't get the pulley off to replace it.Maybe your Crank Position Sensor? There's a common problem with the wire rubbing on accessory belts and causing it to short out and blow the fuse. O2 Sensors can also blow the fuse if the wires get shorted/burned through.
