I installed some indiglo gauges today. When i unpluged the wires from the back of the gauge cluster i noticed that my gas needle wasn't on E ( like it does when the car is turned off). Once i finished my install of the gauges and hooked everything back up the gas needle was still in the same spot. I drove around and the gas needle still works because the needle went down some, it just doesn't go to E when i cut the car off. can anyone help me? please.
the gas needle never drops to E after car is turned off, even if ur have a full tank the needle stays at the point of how much gas u have in car...thats how its been on my gauge since day 1...
As long as i have had my car, it hs always dropped to E when i cut off my car. Maybe it's just fine now :scratch:. Thanks
Mine is always at the same spot as when it is turned on. My wifes corolla drops to E when it is turned off, but my eclipse exactly like yours, as it should be.
No worries, as long as it is accurate.
