I just bought new LED bulbs for my Speedo, Tach, fuel, and temp gauges. I disconnected the Battery and installed everything, then put it back in and reconnected the battery. I turned the new lights on and the dash lights stayed on for about 3 seconds and went out, i smelled an electrical burn, and i looked on the back of the Cluster, and there is a small burn mark on the fuel gauge side, where the burn mark goes, looks like it goes to connect to the fuel light.
What would be the easiest way to fix this, and is it going to happen again? Is this solder worthy? or am i just SOL.
I shorted mine out putting the cluster back in (hit the metel bracket). I used solder on it and worked fine
No problem, Glad I could help.
