1 - 2 of 2 Posts
Hey all. Got a problem with my 2000 eclipse. I just bought it off a guy knowing the issue and hoping I could fix it. So here's the issue. It was an aftermarket gauge cluster in it for a 2001 eclipse. Im not sure if the problem is as simple as wrong year but the only thing currently working on the cluster is the speedometer and warning lights. The fuel gauge, tact, etc dont work, and additionally none of them (including speedometer) light up. The only things that work like I said are the warning light/blinkers etc. Any ideas?? All of the bulbs are fine, the 4 fuse in the compartment for the gauges is fine, no burns on the back of the cluster. The only thing I found was a frayed wire which I fixed up. Dimmer is also plugged in and getting voltage. Not turned all the way down haha.
6G72_4_LIFE
check all the screws on the back of the cluster and make sure they are tight they might not be tight all the way so they are not making contact.
1 - 2 of 2 Posts
