1 - 20 of 50 Posts
Hello guys. Greetings from Bulgaria.
I've owned the car for 8 years. I started this project March 2019.
My friends works on the car almost 6 months. A lot of work, money, time is invested in the car. And the most important desire. Some finishing work remains. The car, it has to be tuned to dynojet after 2-3 week. The engine build is made to hold 900HP+ But with this turbo my target is about (400hp on FWD) I plan to be 4x4 to the end of the year and a larger turbo = FP Black.
I'm happy to be almost at the finish line. Almost everything in the car is replaced with reinforced parts. Only the crankshaft, transmission and suspension are stock.. but not for long.
This is the small parts list: I'm probably miss something.
4G64 Block
4G63 Head (completely revised)
TD05HR-16G hybrid (boost from 2750rpm)
ARP Head Studs
Wiseco Rods
Wiseco Pistons 87mm.
KingRacing Bearings
Injectors precision 880cc
JM Fabrication custom turbo flange
Evo 9 Intake Manifold
Throttle Body 70mm.
Bigger Intercooler 70mm.
Custom Intercooler Pipe 70mm.
Custom Exhaust Manifold
Custom Downpipe and compleate Exhaust system 76mm.
2 Fuel Pumps stock and wabro 255
Custom Fuel Cell for the wabro 255
HKS Purple Fuel Rail
Aeromotive Fuel Pressure Regulator
New radiator fan
Oil Catch Cans
Head gasket Cometic
Mitsubishi Engine Gasket Kit
Polyurethane engine bushings
Fuel Filter from porcshe
Timing Belt Replacement Kit HKS
HKS Purple Cam Gear for 4G63
Cam Gear Cover - Clear
Fidanza Aluminium Flywheel
ACT Clutch
HKS SQV4 Blow Off Valve
Electronic Boost Controllers wideband
Wideband lambda sensor & Solenoids
HKS Filter for the Turbo
Evo Series 60mm Electric Boost Gauge
Evo Series 60mm Electric EGT Gauge
DEPO Oil temps and oil pressure Gauge
Stock Eclipse ECU + Evo 8 custom soft
BREMBO Completely revised, EVO 8 Front end Rear
Ebc yellow stuff front and ebc Red stuff rear
ENKEI Wheels Evo 8 painted
FEDERAL RSR 595 - front 235/45/17 (140 treadwear)
Dunlop sport maxx - rear 245/45/17
Heat Protection
Mitsubishi OEM Water Pump
Radiator Hose
I plan to buy D2 Coilovers and better transmission.
And this is "some" photos
I will upload more pics soon. I hope you enjoy my project. ;)
WOW! Good job, man! Glad to see a good quality build! Keep us updated! Can't wait to see dyno plots. Maybe post a video of it on the dyno if you can.
buddd - thanks
I hope in two weeks. I'll make a video too. ;)
and more photos...
Stock engine
stock piston
not so stock :D
its stock i promise :D :D
Stage 1 SDS @11+ psi
Very nice! What is the CR of the pistons?
Reactions: Gotti
The car is ready to go to dayno.
I have to develop the engine a little bit maybe 1000km. I'm afraid the transmission will break. But will see that. Тhe car needs suspension.. :(
Before and After
blue rings
:devilish::devilish::devilish:
Discussion Starter · #11 ·
Discussion Starter · #13 · (Edited)
Bad news. The car broke a Diff and transs on 0.8bar. at 365hp. (I expect that, but not to soon...after all, it was stock)
I ordered the new one with much stronger Diff and gears. We replaced the injectors (560cc) with much bigger (880cc) and the fuel lines. I hope with everything is ok and boos the car to 1.4bar. to 400+hp
With the new settings on the fuel and injectors the car boost at 2750rpm ;)
This is the reason why i broke the diff and transs :(
I'm sure it would be easier for you to pick up a Quaife lsd over in Europe than it is for us here in the states :giggle:. Our ECUs output a saturated injector pulse so a peak and hold injector isn't the best choice, although it works. You'll most likely notice a rougher idle/cruise and more fluctuations in afrs.
Discussion Starter · #18 ·
You're right. We turned off cruise control. Tmorrow I'll set it to 1.0 bar on the road. And after that to the dyno to 1.40 bar.
1 - 20 of 50 Posts
