gt/gts engine swap
8204 Views 6 Replies 5 Participants Last post by  Krooked
i have a bone stock 02 GT 5 speed with 165k on her. long story short i blew the motor. i came across an 04 GTS motor with 56k on it for $400 bucks. great deal. being new to the eclipse family i was initially unaware of the different compression ratios between the two years as well as the GTS intake manifold. i have tried searching on here for a few hours and am catching bits and pieces of info on swaping the GTS into a GT but not a definative answer on what else i will need to complete the job. do i need an GTS ECU due to the intake manifold or can i use the intake from my GT motor? would the GT ECU work with the different compression the GTS has? basically just looking to see what the best way to go about this is and for the third time posting this i hope im in the correct forum, as gt/gts specific was not right nor 3g general discussion? not trying to rattle anyone's chain here just trying to get some help from fellow eclipse owners. thank you
1 - 7 of 7 Posts
Swap in a 6G74
6G75 if you feel adventurous!
well i already have the GTS motor in the garage. i was really just looking for a quick somewhat simple swap. im not new to replacing motors just new to the eclipse family. just curious as to what all it requires to do this swap in particular
Sell the GTS motor for 5-600 make some profit and get a 6g74
GTS motor is higher compression and the ecu carries a tuned rom that is much more retarded than the GT. If you go on with the swap you'll want to flash on a GTS rom to keep things safe.
ill go ahead and call down to the yard and get the ECU he still has it. should i get the wiring harness too so the intake work will be a breeze or wire it into the existing harness? and lastly ill need to have the ecu flashed for my keys correct?
1 - 7 of 7 Posts
