I'm working on my wife's older eclipse. It's a 3.0v6 with 79k miles. It had a misfire so I gave it a tune up (plugs, wires, distributor rotor and cap). After the tune up it got worse. It stalled out alot. You couldn't barely drive it without it stalling. And the idling was all over the place while in park. A mechanic diagnosed the iac as the issue so I had him replace that. It ran for a couple days and then started stalling again. I then replaced the distributor unit. The reason I did that is bc I see alot of people saying the rotor goes in 1 way but it would spin a full circle when I installed it. Needless to say I figured I fucked it up and I replaced the entire unit. Not I'm getting codes p0335 and p0340. I'm going to assume maybe it's a faulty distributor or would that be a crank issue/timing belt? I just don't understand how I'd get codes for a misfire. Then an iac. Then the crank. Each set of codes coming in after I fix the previous code.
