To start off with I search, but I'm not quite sure how to word my problem so i haven't had luck with this. Earlier this year I bought Spec-D tuning dual halo projector headlights for my 2000 GT. They worked perfectly fine, but the lights were not bright and I had a very difficult time driving without my fog lights on at night. So I decided to buy xentec H1 8000k HIDs, they came in today and I tried to plug them in. Now I'm not new to wiring and electronics (I study electrical engineering in college), but this has me baffled. I took out the ballast and bulbs, the bulb fit no problems (oh these bulbs are only low beam i'm not sure if that could be the culprit). But the wiring was weird, the male wires that connect the headlight to the power were small...So I cut these wires and used the old ones. Very simple because only one power and one negative and hooked everything up like it would be. Then the HID turned on for a second, flickered then both lights (amber and the HID turned off). I'm not quite sure if the amber bulb burnt out or what happened...
After playing with the two ballasts and different bulbs, I used my friends ballast, and got the same problem. Now I tested my ballasts connecting the bulbs straight to the battery and discovered my ballasts were shot (but what can i expect I went cheap). However, my friends ballasts worked and the bulbs when connected to the battery directly worked. The second I hook them up to the harness they flickered and went off. After hours of messing with it, I said screw it and put in the stock bulbs and put the wiring back to the way it was. This whole time I only worked on the drivers side headlight, never touched the passenger side.
After wiring the headlight back to stock, everything was acting weird as all hell. The projectors on both headlights worked, but the regular amber bulbs were both extremely dim, also the halos (which were never messed with) are now not working...Unless I have only the side markers on, then the halos on the drivers side work. If I have the high-beam on, nothing changes with the lights except now my driver's side halo turns on....I have no idea what to do.
In the troubleshooting process the few things I tried for the HIDs are as follows:
Changing the ground connection (the headlights had a separate ground wire attached to the projector)
Changing the fuses for the lights (I thought that perhaps the HIDs were taking up all of the power draining both bulbs)
Using different ballasts and bulbs that are both properly working from my friends car and got the same problem that i did in mine.
I think maybe the relay is screwed up now...When I drive now the projectors turn on, as do the other bulbs, but they are very dim....I have no idea what to do at this point. I'm not even trying to do HIDs at this point...I'd love to but at the moment I just want my lights to work properly. I can provide pics if need be.
