1 - 13 of 13 Posts
The Car:
-Pyrometer EGT with probe
-Auto Meter Oil Pressure (electrical)
-Auto meter Boost (mechanical)
-Triple gauge pod
-Zetronix digital a/f
Turbo
-Turbonetics t3/t4e 60 trim .48a/r exhuast side. freshly rebuilt
-SS Oil feed line
-SS Oil return line
Wastegate
-Tial 35mm external dumped set @ 6PSI
Fuel
-RC 275cc injectors
-Injector clips
-vortech FMU
-SAFC
Intercooler
-PWR Water to air IC
-22.5 lph water pump
-Heat Exchanger
-SS braided lines
Piping
-Tubular manifolds
-Y-pipe
-Downpipe
-all are wrapped with header wrap
BOV
-Recirculating HKS SSQ
-Cone filter on cold air extension prior to MAS adpater.
-Spal 11 in 810 CFM Push & pull fan
-Zex Plugs
-Greddy Evo
-Eibach Prokit
-Koni Yellow Fronts
-Tokico Rears
-Brian VanPelt Strut tower bar
-MOMO Arrows 17x8
-Camber kit
-ST Sway Bar
-TYC tails
-Clear Corners
-Clear Third brake light
-Alpine 240 watt head unit
-MB Quart speakers all around
-Orion 350 watt amp
-Orion 12 in Subwoofer in bandpass box
-1 farad capacitor
-Optima Red Top Battery
-interior neon lighting with kill switch
-Razo Shift knob
-APC pedals (yes APC, but they are acutally nice ;) )
-ProFlow Throttle Body
-Test pipe with MIL eliminator
-Red Wavmixer hose kit
-Red grounding kit (forgot the name TheLife makes it)
-Painted Engine bay-Injen Fuse Box Cover
-Injen Oil Cap
-Wings West Bullet Wing
-Naxos 6000k HIDs
-Apexi Turbo Timer
-'03 headlights
-B&M short shifter
-Energy Suspension shifter bushings
-Energy Suspension Sway bar and bushings
-ACT Heavy Duty Clutch
-Fidanza Flywheel
-Deyeme Racing firm rear motor mount
Just finished last night. Going tomorrow to get the downpipe back exhasut reflanged so it can be hooked up to the evo :D Hopefully early next week I can get a dyno tune and numbers. I will be on vacation tho so bare with me.
Discussion Starter #4
Tearstone said:
Hiii Jooe!
Brings up the Orlando Turbo count to: 3
... more to come ;)
:D
Tearstone said:
Club3GFL Orlando Turbo Install Team:
Left to Right: (Standing) Tearstone ~ Mech/Turbo, 3GwithVolks ~ Rubber Mallet Master, (non 3g owner, IC specialist), OrlandoGT ~ Helping hand, (1G TSi AWD owner, IC specialist). (Kneeling) Neffarious ~ Owner, Daves2001EclipseGT ~ Electrical.
It's like we are on a episode of Pimp My Ride, yo have our names and the area that we work on!! :twothumb:
Anyhow Great car Joe It was alot of fun putting your set-up together! My goal is 2 months!
gj
outfuckinstanding!:wackit:! Cant wait to hear more once you get it tuned. how long did the entire install take (turbo/IC)? Where is the MAS? I can't find it in the pic... GJ and congrats!
Kampfbereit
Well... since heavy drinking was involved the biggest core of the install took us two days instead of one. Joe also had some other things he needed to finish up (weld the oil return fitting onto the oil pan, pick up some misc parts, rework some of the water + fuel plumbing) and had his car up on jackstands for a whole week.
The MAS is before the turbo tucked down into the engine bay.
Discussion Starter #13
I got the wwater pump from newkoba. I don't remember the brand off hand. Its small and powerful :) I do want to get a resevoir of some sort to hold more fluid. Any ideas where i may procure one that will take the abuse of being in an engine bay and still be reasonably priced? So far so good. needs bigger injectors tho. 275cc ius too small for my boost level. MMoving up to 370's :) Shoudl be good for 300whp or so :) Also i am going to remove the stock FPR and go with just he vortech model. My tuner thinks its causing a big restriction. Got all the parts to eliminate it at the house already. now if i only had the time :)
1 - 13 of 13 Posts
