1 - 2 of 2 Posts
Guys, I have the dual halo projectors with 6k HID and today, the driver side low beam wouldnt come on. The projector, projector wiring, ballasts, bulb, and projector side connection work fine. I swapped the entire driver side assembly and tested it on the passanger side. If I connect the HID bulb on the driver side to the high beam, it works fine. SO, I dont understand why the low beam doesn't work on the driver side. I can only assume that the circuit ( from inside the car to the connector) is messed up? If you know about the dual halo projectors youll know that the plug from the car
( LOOKS LIKE THIS | - | ) connects to the projector plug, which goes into the high and low beam. I swapped this projector plug and it works fine. So this means that the connection from inside the car's control switch is messed up?:(
Any idea of what's going on?
1 - 2 of 2 Posts
