Hello guys, this is my first post and im not too sure if im posting this in the right spot but i think i am :eek3:
okay, so i have a question to all of you guys...i have a 03 eclipse with a stock head unit. now, i wanted to order a touch screen and replace it but i am not too sure on size. i measure it and its 7 inches length wise and 8 1/2 diagonal wise, so i am really stumped on what size radio to get? also, im not sure if i have to order a special part or bracket for it to fit?
i need to know this asap cause i want a new radio really bad lol. please help guys, thank you so much!
First off, wrong section. ( I will get this moved)
Second, go to a site like crutchfield.com to view radios that fit. They will give you a list of all the headunits that will fit the space, as well as try to sell you any brackets or cables that would be needed.
Any regular double din should work. I just installed a pioneer avh 200bt in mine. The brackets from your stock unit bolt right onto the new one! Definitely recommend getting a metra wire harness to make the install effortless. ��
