1 - 3 of 3 Posts
Hello, I am going to be replacing the stock injectors currently in my 2003 GS but I am not completely sure how to depressurize the fuel rail. Can it be depressurized directly from the fuel rail or do I have to disconnect the fuel pump to relieve the pressure?
Stage 1 SDS @11+ psi
The fuel pressure gradually drops to zero after you shut the engine off. It takes a little bit. Do your injector change in the morning after your car sits all night. You want the engine to be cold anyways. There will be gas in the fuel rail and the lines so just have rags ready to catch the spillage.
1 - 3 of 3 Posts
