1 - 2 of 2 Posts
Small guide that will work for solution with not working power window
Hello Everybody! I wish to solve my problem and to write everything what I would do, I'll make some pictures and would try to explain some wire diagram, because as for me newbie it was hard to understand at first time, but right now better.
So there is problem - Passenger window would work from sub switch, but not work from main.
1. First of all go and look to wire diagram and estimate what it could be.
a) as sub switch work, and window going down and up with it, it means that relay and fuse is ok;
b) The problem could be in main switch, harness's , or simple lost wire connection between door and body (common issue).
2. So let's look on the wire diagram in normal state
<a href="http://www.flickr.com/photos/[email protected]/7469343476/" title="normal.state by kazaroza90, on Flickr"><img src="http://farm9.staticflickr.com/8017/7469343476_4de20b755a_c.jpg" width="800" height="525" alt="normal.state"></a>
To figure out what is the problem switch or wires, I'm going check the wire
and expect to see the same result as on diagram ( mean ground on 7,8 ; positive on 6) on main switch
3. When main switch pass. window up such picture of current flow
<a href="http://www.flickr.com/photos/[email protected]/7469342840/" title="passenger window UP(m) by kazaroza90, on Flickr"><img src="http://farm8.staticflickr.com/7253/7469342840_686200a09e_c.jpg" width="800" height="525" alt="passenger window UP(m)"></a>
What I expect to check - I'll put direct positive from battery to pin#7 and if it is go up, the problem is in switch.
4. When main switch pass. window down such picture of current flow
<a href="http://www.flickr.com/photos/[email protected]/7469343208/" title="passenger window Down(m) by kazaroza90, on Flickr"><img src="http://farm8.staticflickr.com/7123/7469343208_d5f4b70549_c.jpg" width="800" height="525" alt="passenger window Down(m)"></a>
The same operation try to apply positive to the pinN8
5. Here is the picture of currents flow when use switch on passenger side
<a href="http://www.flickr.com/photos/[email protected]/7469343624/" title="passenger window UP(S) by kazaroza90, on Flickr"><img src="http://farm9.staticflickr.com/8005/7469343624_fbc18397a9.jpg" width="500" height="328" alt="passenger window UP(S)"></a>
And down
<a href="http://www.flickr.com/photos/[email protected]/7469343030/" title="passenger window Down(S) by kazaroza90, on Flickr"><img src="http://farm9.staticflickr.com/8027/7469343030_87feac1f44.jpg" width="500" height="328" alt="passenger window Down(S)"></a>
So please I need advice also, Is my suggestion are right and is my checking would be right, because it's only in theory. And I hope to have the same situation on practice. I'm wish to learn and to help another people may be with the same situation. Thank you and would very grateful to hear some good advice from you guys !!!
UPTADES AFTER GET CHECK THIS WIRES
1.Okay, I got checked my switch, and it's look like okay, also I took out the sub switch from passenger side and try to check for continuity the pin#7 and pin#8 for break and get pretty upset, because they are okay.
2. So next step I run voltage drop test. As you know when load is applied the voltage is dropping to zero (ideal case) usual to 0,5 if it's not drops it's means there some shortness.
a) So I checked normal state between pin 6(power) and pin 7(ground), pin(8) ground - if wires okay you should get you 13V
<a href="http://www.flickr.com/photos/[email protected]/7473776838/" title="NS - voltage by kazaroza90, on Flickr"><img src="http://farm8.staticflickr.com/7135/7473776838_e41671b583_c.jpg" width="800" height="338" alt="NS - voltage"></a>
b) Okay, put switch in down position, and should get voltage drop between 6 and 8 - got 0,5V - it's mean that VD is appearing on motor and should move it down. Back to normal position and you again will get your 13V;
<a href="http://www.flickr.com/photos/[email protected]/7473776952/" title="DOWN - voltage by kazaroza90, on Flickr"><img src="http://farm9.staticflickr.com/8154/7473776952_7fa26d92c4_c.jpg" width="800" height="338" alt="DOWN - voltage"></a>
c) Put switch in up position , VD should be between 6 and 7 - got 0,5
<a href="http://www.flickr.com/photos/[email protected]/7473776716/" title="UP - voltage by kazaroza90, on Flickr"><img src="http://farm8.staticflickr.com/7251/7473776716_3b2646b271_c.jpg" width="800" height="338" alt="UP - voltage"></a>
SO FOR MY UPSET I GOT EVIDENCE THAT WIRE AND SWITCH IS WORKING. But nothing more - the passenger window still not moves. It's was okay, but passenger switch moves the window.
So please tell what it could be more, that I should check. I will report with pics and it would be very useful for people with the same issue. Common people I need your suggestions.
NEXT STEP
Going to measure resistance ( ignition on, engine off)
a) between pin7 on main switch and pin8 on sub switch ; between pin8 on main switch and pin5 on sub switch ;
In such test you testing wires for continuity and shortness.
b) Test with battery applied to PIN 6 (Power) and PIN9. Check resistance on output pins
<a href="http://www.flickr.com/photos/[email protected]/7475499400/" title="resistance by kazaroza90, on Flickr"><img src="http://farm9.staticflickr.com/8027/7475499400_cb87e8545b_b.jpg" width="1024" height="276" alt="resistance"></a>
Also very interest fact - resistance appeared on test with battery - 9V, when I tried to check how the switch working and to be sure that there no shortness on the printed circuit board I got it in position UP for left window, and in position Down for right window. Also in this position test for continuity working and you can hear beeping from multimeter.
Interest that on position down for left window switch, and up for right window switch no continuity, no resistance.
TEST WITH BATTERY 9V - FOR COMPARISON WITH WORKING SWITCH
Okay, I did such test, simply applied power to pin 6 and ground to pin9 , in different position I got different voltage on output, as on left switch ( driver window that WORK) and on right switch (passenger window) that not work.
<a href="http://www.flickr.com/photos/[email protected]/7475499238/" title="test with battery by kazaroza90, on Flickr"><img src="http://farm8.staticflickr.com/7136/7475499238_9833417068_b.jpg" width="1024" height="251" alt="test with battery"></a>
TEST WITH WIRES ON THE CONNECTORS
Okay, here some interest question, that I could understand why it's happens. Maybe it's the key for answer on this problem.
Run the test on harnesses on main switch on pin 6(power) and pin7 or 8 - I got voltage about 5V
<a href="http://www.flickr.com/photos/[email protected]/7475499104/" title="VOLTAGE on right motor by kazaroza90, on Flickr"><img src="http://farm9.staticflickr.com/8006/7475499104_13f901576a_z.jpg" width="640" height="433" alt="VOLTAGE on right motor"></a>
The same situation appeared on sub switch.
The most interest that I run the same test for left window motor and get usual 0.01V on both pins 1,5. Like without load.
<a href="http://www.flickr.com/photos/[email protected]/7475499520/" title="working switch by kazaroza90, on Flickr"><img src="http://farm8.staticflickr.com/7131/7475499520_b7fd57c44f_z.jpg" width="640" height="137" alt="working switch"></a>
But anyway, if the voltage the same as on main switch as on sub switch. Why the sub switch doing its job ?
1 - 2 of 2 Posts
