Chalk City Bitch
I know these were somewhere in the original Biggest Loser threads... but I think they are still valuable to those that need them:
BMR Calculator
Basal Metabolic Rate Calculator:
You use energy no matter what you're doing, even when sleeping. The BMR Calculator will calculate your Basal Metabolic Rate (BMR); the number of calories you'd burn if you stayed in bed all day.
If you've noticed that every year, it becomes harder to eat whatever you want and stay slim, you've also learnt that your BMR decreases as you age. Likewise, depriving yourself of food in hopes of losing weight also decreases your BMR, a foil to your intentions. However, a regular routine of cardiovascular exercise can increase your BMR, improving your health and fitness when your body's ability to burn energy gradually slows down.
Once you know that you can go here: Harris Benedict Equation
The Harris Benedict Equation is a formula that uses your BMR and then applies an activity factor to determine your total daily energy expenditure (calories). The only factor omitted by the Harris Benedict Equation is lean body mass. Remember, leaner bodies need more calories than less leaner ones. Therefore, this equation will be very accurate in all but the very muscular (will under-estimate calorie needs) and the very fat (will over-estimate calorie needs).
First, determine your BMR using our BMR Calculator or our BMR Formula.
Harris Benedict Formula
To determine your total daily calorie needs, multiply your BMR by the appropriate activity factor, as follows:
1. If you are sedentary (little or no exercise) : Calorie-Calculation = BMR x 1.2
2. If you are lightly active (light exercise/sports 1-3 days/week) : Calorie-Calculation = BMR x 1.375
3. If you are moderatetely active (moderate exercise/sports 3-5 days/week) : Calorie-Calculation = BMR x 1.55
4. If you are very active (hard exercise/sports 6-7 days a week) : Calorie-Calculation = BMR x 1.725
5. If you are extra active (very hard exercise/sports & physical job or 2x training) : Calorie-Calculation = BMR x 1.9
Total Calorie Needs Example
If you are sedentary, multiply your BMR (1745) by 1.2 = 2094. This is the total number of calories you need in order to maintain your current weight.
Once you know the number of calories needed to maintain your weight, you can easily calculate the number of calories you need to eat in order to gain or lose weight.
Calorie Needs to lose weight
There are approximately 3500 calories in a pound of stored body fat. So, if you create a 3500-calorie deficit through diet, exercise or a combination of both, you will lose one pound of body weight. (On average 75% of this is fat, 25% lean tissue) If you create a 7000 calorie deficit you will lose two pounds and so on. The calorie deficit can be achieved either by calorie-restriction alone, or by a combination of fewer calories in (diet) and more calories out (exercise). This combination of diet and exercise is best for lasting weight loss. Indeed, sustained weight loss is difficult or impossible without increased regular exercise.
If you want to lose fat, a useful guideline for lowering your calorie intake is to reduce your calories by at least 500, but not more than 1000 below your maintenance level. For people with only a small amount of weight to lose, 1000 calories will be too much of a deficit. As a guide to minimum calorie intake, the American College of Sports Medicine (ACSM) recommends that calorie levels never drop below 1200 calories per day for women or 1800 calories per day for men. Even these calorie levels are quite low.
An alternative way of calculating a safe minimum calorie-intake level is by reference to your body weight or current body weight. Reducing calories by 15-20% below your daily calorie maintenance needs is a useful start. You may increase this depending on your weight loss goals.
Calorie Needs to gain weight
Once you know the number of calories you need to maintain your weight (using our BMR Calculator in conjunction with our Harris Benedict Equation, you can easily calculate the number of calories you need in order to gain weight.
If you want to gain body weight, you need to consume more calories than you burn. One pound of body weight is roughly equivalent to 3500 calories, so eating an extra 500 calories per day will cause you to gain one pound a week.
For optimum health, if you increase your calories to gain weight then (health permitting) gradually increase your level of physical exercise in order to maintain or increase your lean body mass. The benefits of exercise on physical and mental health are well documented and shouldn't be ignored.
Motivational Speaker
Thanks, had been looking for something like that. Apparently, I have been maintaining diet of about my BMR while being somewhere between moderately active and very active (hard exercise 5 times a week.) I can easily add some calories and stay well under even BMR*1.55.
Interesting, according to that, to maintain my weight of 162 lbs I need to consume 2,781 calories per day.
My BMR is 1794.26
I would say I'm in the moderately active range so that's 1794.26 x 1.55 = 2,781.10 calories per day to maintain that weight.
That seems kind of high? Although I could be way off on how many calories I'm eating per day to start with? I think I'm right around 2,000.
Interesting.
I was thinking it was kind of high as well. My BMR according to that was around 1850 and using moderately active 1.55 multiplier gave 2858.
I was probably consuming over that 3 months ago, but over the last couple of months I have been in more of the 1500-2000 a day range (usually on the lower end of that.)
