As many of you know I am running a Haltech E8 EMS, and plenty of other goodies. Anyways, since the EVAP system is eleminated along with the valve, solenoid, EGR pipe etc...
Now since the gas tank uses, those parts as part of its emission system. You have basically 3 lines running from the tank. A fuel feed line, a fuel return line, and a fuel fume/gas line. Now considering that you dont have this EVAP system anymore. And the fume line line is blocked off, you can assume that during warm weather those hot gases will build up in the gas tank and can cause vapor lock in the fuel feed lines an cause the car to sputter.
Now if you would run a line with a one way valve from the fume/gas line that runs into the engine compartment, that used to be part of the EVAP system, then let it run to the intake manifold. (Think of the way the brake booster is constructed.) Would you expect it work similarly to that of the old EVAP system, that under vacuum it would suck those fumes out and then under boost the valve would close, and boost would not sneak into the gas tank?
Discuss.
Discuss.
