21 - 35 of 35 Posts
2005 Spyder GT
looked at the diagram. theres no fuse there :-(
give me your VIN# and I'll look it up on the Mitsu ASA parts database. I remember another thread where the member had a hard time finding the location of the relay, so it may be different by year, model, engine, etc.
2005 Spyder GT
its not a fuse, its a relay and looks like a little grey box. If you have an Auto trans, you might not have a starter relay, in which case I reccommend disconnecting and cleaning the connections at the starter with some sand paper.
2001 Spyder GT. Koni adjustable shocks. ST sway bar.17X8.5 rims. LED headlights.
I thought you were replacing the starter RELAY. It is a small black or grey plastic cube about 3/4" square. What fuse are you talking about ? ...J.D.
Discussion Starter · #28 ·
i know where the relay is....problem is there's no relay in the fuse box to begin with but the car starts up 4/5 times no. someday it starts up all the time. now a lean code popped up this morning (p0171)
and i cannot find the vacuum leak.......at least the car starts and drives now.
I think this guy is wasting our time. ...J.D.
2005 Spyder GT
You didn't say if your car is auto or manual trans, but I have read elsewhere that auto trans DOES NOT have a starter relay. So if auto, move on to next possible culprit, such as wire connections to starter, bad spot on starter, neutral safety switch, etc.
Super Moderator
This type of language is not allowed on this site. Your opinion of the person you speak of may be true but please refrain from voicing it in the public domain. What is said in a private message is between the two parties...... :);) This is not a warning...just a reminder to keep it clean in the open forum...Thank You
Discussion Starter · #33 ·
Hey sorry working a lot, but it's an automatic. so it makes sense now why it doesn't have a relay.
Discussion Starter · #34 ·
Alright!!!!!!!!!!!!!! i found out what happened!!!!!!!!!!!!!!!!!! my friend did not put in the harmonic balancer after the timing job correctly. so the belts was slipping and caused my intermittent no start.
21 - 35 of 35 Posts
