1 - 3 of 3 Posts
· Registered
just re bought my old gts spyder. Everything looks fine except it has a high idle now. I just had the clutch replaced and when I got the car back it was idling at about 2k and the cold air intake is REALLY loud any advice?
· Registered
You might pull the air intake off and check that the throttle butterfly is fully closed at idle. The excessive noise may be coming from air moving through the gap. On these engines the throttle plate should be fully closed at idle. Check that the cable is adjusted correctly. That would also cause the idle to be too high. There should be no tension or slack on the cable at idle. Mechanic may have not got it on correctly. ...J.D.
1 - 3 of 3 Posts
