1 - 11 of 11 Posts
turbo? unf unf!
like he said. you can adjust it so it opens up when there's lots of pressure.. or little pressure.
turbo? unf unf!
i use the JDM greddy type s. haven't had a single problem with it
great little thing. I hear good things about the HKS SSEV though? =)
E
Guest
All it does is tighten the spring those are bad ass blow off valves i got them on both of my eclipses.
Discussion Starter #8
it's working out good for me, I just wanted to know what that bolt was for. So, if I tighten it it will not blow-off under vacuum and if I loosen it will blow-off pretty much all the time, even under vacuum? did I get it right?
C
Guest
Yup, less threads = tighter spring, more threads = looser spring. I had that blow off valve and it seemed to work fine at the 9psi that I was running.
Discussion Starter #10
Ok, another question, what is the other nipple for? on that picture you can't really see it but there's another one there that looks just like the vacuum one.
1 - 11 of 11 Posts
