I was thinking about changing my filter on my sds to an hks mushroom one so it is easier to get in and out any body think this will work out ok just check to see what people think casue of the vaccum line that goes into the filter
Ah yes...
The vacuum line does not go into the filter, thats part of the crank case relief system, its the same as it would be stock. You can change out to any filter you want, it dosent matter. There are NO vacuum lines running to the air filter.
Ah yes...
rippedeclipse said:
why does it go into the filter with the sds then just wonder never knew
Because thats how it worked in the stock system, it went into the air intake. Or you can let it vent to atmosphere, a breather filter, a catch can, or into the intake.
