1 - 20 of 20 Posts
I would just worry about getting into an accident and having that fuel cell explode, but other than that it sounds promising.
So you're not worried about getting in an accident and having your gas tank explode now?
The LEL of hydrogen in air is way lower than gasoline, and since it's a gas, not a liquid the explosion potential is much greater if the tank ruptures.
but H is lighter than air, where as gasoline vapors are heavier and linger. a cracked H tank will vent and the gas will escape up and away. gas fumes would settle under the car and linger in ditches and low laying areas. i'd feel safer with a fuel that escapes and floats away than one that spills and remains a liquid on the ground and turns into a heavy vapor.
Maybe for a slow leak, but for an impact (such as an accident) where an ignition source is present, the LEL of hydrogen would make me think twice...pictures of zeplins engulfed in flames suddenly come to mind...:bombinsert:
it was the skin that burned violently, not the H gas.
That's only if you have a slow release, which isn't likely in an accident, nor when you have H2 at high pressure or in a liquefied state. Nevermind the fact high concentrations of H2 can auto ignite in air under the right conditions.
And in the Hindenburg, the H2 burned quite readily, its just that it burned hot enough to ignite the metallic skin, which burned more violently.
I Wangs
Discussion Starter #16
actually the hindenburg ignited because the skin was basically covered in what amounts to rocket fuel. there was just a show on about that a couple months ago.
as for the tank exploding...:dunno: shit happens.
as for fueling it, right now it's only on lease in cali because that's where the fuelin stations are. eventually not only are they working on the home refueling thing but also all honda dealers will be refueling stations. ask your navigation system where the nearest dealer is and presto.
Generally Bitter Admin
Autoblog Green said:
First Drive: 2009 Honda FCX Clarity, world's first series production fuel cell car
What you see pictured above is the world's first fuel cell-powered car designed from the ground up expressly for that purpose with series production in mind. It's not converted from any existing vehicle like the Chevy Equinox, Toyota Highland and Ford Focus that you can find elsewhere on this site. The Honda FCX Clarity takes the layout and design themes first seen in two years ago in the FCX concept to completion. As we reported earlier this week, the FCX Clarity will be available for lease to retail customers beginning in the summer of 2008.
In the days following the world premiere of the FCX Clarity at the LA Auto Show, Honda invited a select group of journalists to drive a pair of pre-production examples in Santa Monica. As pre-production samples, these two cars are essentially hand built but using production tooling. Some reports have the value of these cars as much as $10,000,000 which may or may not be accurate for the current stage of development, but read on after the break to find out what happens when bloggers take to the PCH and Malibu Canyon in Honda's latest creations.
Before we got to hop into the cars, some of the chief engineers and designers on the FCX program gave us a briefing on technical and design details. The soft-spoken VP of Honda of America R&D, Ben Knight, started things off with some background on the company's efforts in developing more efficient, less polluting technologies such as the CVCC engines of the 1970s and the EV-Plus battery electric of the late '90s and on to the fuel cell and diesel power-trains under development today. Knight may be soft-spoken, but like GM's Larry Burns, he is very much a hands-on engineer with a passion for developing new technology.
While facilities for retail distribution of hydrogen are obviously extremely limited right now, Honda is actively working to change that too. Honda Soltec recently started production of new photo-voltaic cells that only require half the energy input to manufacture of current cells. Their Torrance, CA headquarters campus has a hydrogen filling station that features two different H2 generators. A solar powered electrolyzer produces the gas from water, while the experimental Home Energy Station has a natural gas reformer.
With the most common way of producing hydrogen right new is steam reformation of natural gas, CO2 emissions still remain a concern. However, when well-to-wheels CO2 emissions are evaluated in comparison to gasoline engines, steam reformation and fuel cells show a sixty percent reduction. For solar powered electrolysis, Honda has proton exchange membrane electrolyzer that basically functions as a fuel cell in reverse and is eighty percent efficient. Although home hydrogen generation is still a ways off, centrally produced hydrogen is being distributed via pipelines right now. Shell will open be opening a hydrogen station in Los Angeles next year right on an existing 8" hydrogen pipeline.
Exterior Design Leader Masaru Hosagawa explained that the body of the new FCX was specifically designed to highlight the tiny drive-train that propels this relatively large car. The FCX takes the cab forward design ethos to a whole new level with the base of the windshield starting at about the front wheel center line and sweeping all the way back to the edge of the trunk lid in a continuous curve dubbed Dynamic Full Cabin Design. Combined with the super compact vertical flow fuel cell stack that sits within the center console, the FCX has an almost limousine-like interior volume for four passengers.
Speaking of the passengers, keeping them in climate-controlled comfort is important but regulating the temperature of such a large interior volume can consume quite a bit of energy. One way to minimize that energy is to regulate the temperature right at the surface of the occupants. Since the largest point of contact between the passengers and the car is the seats, Honda has chosen to provide a climate control system within the seats. Fans draw air into the front seats where a thermo-electric device chills or heats it before blowing it through pores in the seat cushions. The end result is greatly reduced demand on the climate control system.
The FCX Clarity has remained remarkably true to the concept with the most obvious visual difference being the nose. The production car has been stretched out by a few inches in order to provide crush space for crash protection. The grille has now been moved above a new chrome bumper strip taking the place of the previous full-width light bar. In profile the base of the windshield extended even farther forward and the front quarter windows were part of the body. Those windows are now smaller and integrated into the doors instead. At the back, the full width tail-lamp cluster is now slimmer in the middle providing room for an extra piece of vertical glass aiding rear visibility with the high deck.
That tall deck combines with a fuel tank mounted down low between the rear wheels to provide for much more trunk room than other converted fuel cell cars. Including the under floor compartment, the total storage volume is 13.1 cu. ft. The fully-appointed FCX is equipped with all the modern conveniences such as a satellite navigation system, adaptive cruise control, electronic stability control. All of this is combined in an aluminum structural cage that provides protection for the passengers and the fuel system.
Chief Engineer Sachito Fujimoto described the FCX platform as having been designed to be lightweight while providing maximum safety. The FCX is designed to meet and surpass all safety standards in the US and elsewhere. When this car becomes available next year, it won't require any safety waivers. The 5,000 psi hydrogen tank is designed to withstand any impact it might see in the real world. While the first generation FCX used a two tank storage system, the new car has switched to a single-tank setup. Previously separate components like the pressure sensor, regulator and shut-off valve are now combined in one module mounted in the tank.
Having only one tank means fewer connection points that can fail so that safety is enhanced and installation is a lot simpler. A single larger diameter tank has greater capacity in less overall space than two smaller tanks. The bottom line is seventy-four percent fewer parts and twenty-four percent better storage efficiency.
One problematic aspect of many previous fuel cell vehicles has been high weight. The Chevrolet Equinox Fuel Cell being used for that company's Project Driveway weighs over 4,400 pounds and the Sequel concept reportedly weighs over 5,000 lbs. Even the much smaller Ford Focus FCV weighs in at 3,600 lbs. The new FCX Clarity weighs in at 3,582 lbs, which is only about 175 lbs more than the similarly-sized 2008 Accord. Doing a ground up design around a fuel cell power-train has allowed Honda to optimize it for the purpose.
That pays off in the ride and handling of the Clarity. While some other cross-over type fuel cell vehicles definitely feel more truck like on the road, this car is pure Honda. Jonny Lieberman and I set out from the Fairmont Hotel in Santa Monica in one of the two FCXs and headed west on the Pacific Coast Highway toward Malibu. In a region heavily populated with Ferraris, Porsches, Aston Martins, Rolls Royces and Bentleys, the futuristic looking FCX seemed to draw remarkably little attention from other occupants of the PCH.
I Wangs
Discussion Starter #18
for someone that knows jack shit about computers, Sam is the internet GOD! :lol:
Thats not entirely correct. And no one can really definitively say what ignited the blimp, only theorize (there were many reports that hydrogen was leaking out from the skin before the fire started). The skin was not covered in rocket fuel, but it did have iron oxide and powdered aluminum on it which are components thermite which makes up rocket fuel, but doesn't constitute rocket fuel by themselves. Mythbusters did a show where they built model blimps with varying skins and had an ignited hydrogen purge flowing over it. One used the same combination of materials as the Hindenburg (with and without the presence of hydrogen), and another covered in thermite paint. The model resembling the Hindenburg went up 50% quicker with the hydrogen then without. The thermite blimp was a pretty impressive fireworks show though. So they concluded the hydrogen is what ignited the blimp.
1 - 20 of 20 Posts
