1 - 3 of 3 Posts
I have an 03 GTS manual trans. I ended up throwing the alternator belt and that in turn caused the power steering belt to fall off and slip between the motor and the crank pulley which warped my pulley and sheared off the roll pin. After I got it fixed it now idles rough and dies, and you can hear it kinda pop at idle. I was wondering if this could be bent valves. I would do a compression test but that would require taking off the intake manifold I believe and labor to take that off costs around 200-300 at the place I go, which if I am going to be told they are bent and I need a new motor I don't want to pay that to have to pay way more after. Also my transmissions 4th gear is gone so if the valves are bent I will most likely have to get rid of it. Also it threw three codes when I read it with an OBD2 sensor and they were P0660, P0340, and P0335
1 - 3 of 3 Posts
