21 - 40 of 53 Posts
Just Married 05-15
FFFF = Nothing, its hard to explain but its there just to fill in the empty memory blocks. If you have that, that means you have your immobilizer disabled and the code was removed.
GS-Turbooo
I'm sure thats what it does because my car was doing that when I would start it without the correct transponder. (Start like normal, shut off over time, flash green key symbol in gauge cluster)
Filling in the code with FFFF could just be a filler for those who do delete their immobilizer, but entering FFFF does not actually delete it... so just because you have that doesn't mean your immobilizer is disabled, it just suggests that.
The case where you do have FFFF but do not have a disabled immobilizer is when you get your ROM from someone else who has changed it to FFFF to protect their own immobilizer code. And why is it HEX FFFF? Isn't 0000 nothing? lol
Kuztom Uzer Tytel
Subscribed, and dualy noted.
turbo? unf unf!
Discussion Starter #24
what do i add to the xml definition file to make this work!!!
turbo? unf unf!
Discussion Starter #25
i tried all of those periphery codes in the definition rommetdata from logicgate.. and i still am throwing a code P0513 which is P0513....Incorrect Immobilizer Key
Boosted
You can change the ecu perephery values to get rid of the wastegate solenoid and fuel sensor/relay trouble codes we get from the ECU swap. I saw it over on evom and have been driving for a week now and no codes.
Perephery 0 = 56D2
Perephery 1 = 0009
Perephery 2 = 4DDF
Perephery 3 = C0C0
This also disables EGR functions, evap. emissions functions, and immobilizer.
after putting the lines in the definition, you need to restart ecuflash and then you can view/edit the codes for each periphery location. You then go into each and enter "0x----" with the dashes being filled in with the provided code above, but don't use the quotation marks
turbo? unf unf!
Discussion Starter #28
i put in the new definitions (using logicgate's xml definitions) -- then restarted ecu flash, then reopened the hex, then entered the codes by clicking the "edit", then "set data", then 0xwhatever
turbo? unf unf!
Discussion Starter #30
yay flashbluers actually was the guy i sold my ecu to. he just gave me the immobilizer code and it all works now :)
turbo? unf unf!
Discussion Starter #31
what are you definition files like (the guys who got this working with success.)
i can't seem to get this to work. its annoying me!!
Boosted
hit me up on yahooIM if you have a free minute. I can probably explain it to you easier
Just an update for everybody. We got my ROM working on Zee's car. It flashed in no problem. It appears that the whole periphery thing wasn't working because the definition files were a little screwy for him.
Now its working.
The next step is to switch over to the 94170015 ROM ID, which is supposed to be the same only upgraded and won't throw some code... like p0300 or something like that according to the evolutionm.net. That'll come when I have my car back together and I upgrade to the Tephra's ROM.
turbo? unf unf!
Discussion Starter #36
yea but those periphery values dont work on stock 3g roms
so we made a rom that is based off the 94170015 ecu and interpolated and copied some data from the oem 2003 eclipse rs rom over :)
Boosted
I'm currently running your stock rom with all the periphery stuff changed. Just flash the rom I emailed you and change whatever you want.
Hey Zee, remember your definition was a little wacky? I bet that was the problem with the stock ROM too.
21 - 40 of 53 Posts
