This was pulled from: Matching Your Spring Rate to Dampening Rate
Date: 2004/08/03 Tue PM 03:24:50 EDT
To: Cameron
Subject: RE: [KYB.COM Contact Form] Dampening Rate
The AGX products have the following approximate damping force values.
When adjusted, both rebound and compression damping forces change.
Setting#:
Relative Value
1 - Same as Factory (100%)
2 - Same as our GR2 products (10~15% firmer than Factory --115%)
3 - 50% firmer than #2 (172%)
4 - 30% firmer than #3 (223%)
For an eight position adjustable product, the damping force values are
approx. the following: With #2 being Factory at a relative value of 100,
#1 = 95 (5% softer than Factory)
#2 = 100 (Factory damping force)
#3 = 107.5 (7.5% firmer than Factory)
#4 = 115 (15% firmer than Factory)(GR-2)
#5 = 143.5 (43.5% firmer than Factory)
#6 = 172 (72% firmer than Factory)
#7 = 197.5 (97.5 firmer than Factory)
#8 = 223 (123 % firmerthan Factory)
When using Eibach Prokit springs recommended setting on a 1~4 is no
lower than 2, 1~8 no lower than 4.
To: Cameron
Setting#:
Relative Value
