Hey guys I have recently replaced all 6 of my injectors because a local mechanic said that both 2&6 were stuck open, and I figured just replace them all instead just the two of them. The car definitely runs better than it did before, but when I unplug 2&6 injectors while the car is at idle it makes absolutely no difference in the way the car idles where as if I unplug #4 injector by itself the car begins to run terribly.
Does anyone have any idea what the cause for the two injectors not working could be and what it is that I should check?
Thanks
Thanks
